52 - 54 OD needed
A long time HET member in my Chapter is in need of a good rebuildable 52 - 54 OD. His car is currently OD equipped but there a few concerns which make rebuilding it a less than desirable undertaking.
This transmission mut be rebuildable or useable as is...no junk. (if he wanted junk I would give him one I have here)
Please let me know what you can do
EssexAdv@adelphia.net
Call Jim Harmon @ 503-324-7041 he has many good used gear boxes. I have a 52-54 transmission with O/D that has new bearings and seals installed. The price is $400.00 plus shipping - we both live in the North West.0
Try Lester Harris at (775) 267-2559 In Minden Nevada. Has real good prices!0
I am the one looking for the Hudson (52) T-86-E1A transmission dual lever and overdrive in good usable condition. I understand you may have one for $400 plus shipping that has new bearing and seals already. I assume the gears and main drive shaft and internal parts have acceptable wear.
When and how would you ship it to the east coast?0 -
Also check with Bill Albright,909-823-91680
Does anyone have a good source of parts for the OD units? Such as the rollers and other misc pieces that are in the OD.
Also, I have not been successful in finding input shaft needles that fit correctly (too long). Synchros, bearings, snap rings, and the wear plates for the countershaft I have found - but that's all.
Mark0 -
Try Al Saffrin in Az.0
`Hudsonator wrote:Does anyone have a good source of parts for the OD units? Such as the rollers and other misc pieces that are in the OD.
Mark
Mark,if you need parts for the T-86e trans.,you can call Northwest Transmissions.I believe they are in Michigan.Also,you can try George Bachleda[OlCar bearing co.]in S.C..:)0 -
LAst time I neede the rollers, I took an original to NAPA. They had them for me in 2 days. Good luck hunting0
