31 Essex Super Six Carburetor?
it is a marvel carb, i forget the number, do you have the heat exchanger that bolts between the exhaust manifold and the block, the carb bolts to this. this is a pretty important piece and if you dont have one, you might be beter off making an adapter and running a more readily available carb. i had planned to do this as my heat exchanger was in really poor shape, but i sent it out to be repaired. i am working on getting another 31 engine, trying to iron out some details, ill keep in touch if i get it and it has anything that i might be able to part with to help you.0
ehowe1 wrote:Hi all:
New member who just acquired a 31 Essex Super Six.
The car is complete except for the Stewarts and the Carburetor.
Can anyone provide the correct model for either, and does anyone have a spare? Much abliged.
Carb number - 1931-1932 Essex - Marvel V-10-946
For a complete list of manufacturer numbers for your car, plus much other data, drop by my web site @:
http://www.freewebs.com/hudsontech/index.htm
Click on "Manufacturer's Numbers" and scroll down to 1930-1939. I can also send you the 1931 Essex Mechanical Specifications and Paint Spec sheets - these sheets give you the Paint Options used on different body styles.
Drop me an email @ NEChudsontech09@yahoo.com (drop the NEC)
Alex Burr0
