Need Help! Quarter Panel Bolts MIA!
rambos_ride
Who'd have thought after 2-1/2 years and a move I'd lose something but...I could use a picture and details of the quarter panel bolts and washers for a early stepdown.:o
I believe the "washer" was not a typical shape or was shouldered onto the fastener.
Thing is I can't find ANY of my original ones...I think I found everything else though :mad:
I do remember at least 3 of them were completely rusted away and I broke 2 others taking the quarters off.
Does anyone have a good source for a new replacement set or good condition (not rusty) oem fastners?
are you talking the rear fender bolts?0
hudsonkid wrote:are you talking the rear fender bolts?
Yes, specifically the ones that bolt across the top to the tailights - not the 3 that bolt down then jamb edge.
Thanks!0 -
lemme look...
I thought they had a rectangular washer type affair, and were coarse threaded. Been a while since I had taken a fender off...0 -
The washer/plate is about 2"x1",and the bolt is a 5/16th's body bolt.These are special,as you know,and can probably be purchased from Mel or Ron Falk.Look them up in your roster,they are in Nebraska.You might also try Jim Harmon-Oregon,or Stu Coleman,Mt..I'm sure there are more,just can't think of them right now.Good luck0
Rambos, lemme dig around, I might have a few around here, that I am storing...
I'll let you know tomorrow by lunchtime.0 -
rambos_ride wrote:Who'd have thought after 2-1/2 years and a move I'd lose something but...I could use a picture and details of the quarter panel bolts and washers for a early stepdown.:o
Dan:
I have 10 extra, rusty but salvagable, PM me your address and I can send them the begining of the week. I think 10 will do one side.
Pat0 -
If all else fails, I believe that you can use standard body bolts from GM vehicles by putting a tinnerman clip behind or on (depending on type) the lip of the body. Just 2 cents worth...0
tristansdaz wrote:If all else fails, I believe that you can use standard body bolts from GM vehicles by putting a tinnerman clip behind or on (depending on type) the lip of the body. Just 2 cents worth...
Yeah - I'm using some of those now fitting the hidden hinges in - but what I didn't want to have to do is re-create the 2"x1" washers that spread the load out.
I know what will happen - I'll buy replacements and then find mine! But I was 3 or 4 short anyway...:(0 -
Makes me think I better go out and make sure I remember where I put mine! LOL0
