heater wiring
I had a minor under dash fire in my 52HH a few days ago. I stopped the car quick as I could and jerked a battery cable off to stop it. After I cleared the smoke and changed my pants I got the car home to survey the damage. It turned out the fire was caused by some gadget in the heater power line over heated, melted the jacket on an adjacent wire which shorted to part of dash support and self destructed. This gadget that overheated and caused this mess was apparently put in by some prior owner to reduce the heater motor current after changing from 6V to 12V. That piece of crap sure won't go back in during the rewire process. Now to my question - Can someone tell me how much current the stock heater motor draws when running at high speed. I can figure the value and power rating of a series resistor to put in the circuit if I can get the amperage requirement.
Thanks for any info you can share
George
George
Let me get this straight, your car caught on fire while you were driving, correct? You stopped, got out and pulled the battery cable, etc. Then you changed your pants in the street! Do you keep a spare pair in the car in case of fires? Sorry, but this just sounds too funny.
If your car has been converted to 12 volts, why don't you do the right thing and get a 12v motor? Obviously, rigging it up caused a problem once so why do that again.0 -
I would give all the wiring in your car a thorough checking over. Short of that strap fire extiguishers to each leg.....0
yeah, why would you go to all of the trouble to figure this or that out, instead of getting a correct 12V fan motor? sounds like that would be the easiest route.
Maybe a set of depends would be in order, next time you drive that hudson. hehehehe....
*and you guys wonder why we got our own thread... *0 -
All the underdash wiring is really ratty and I'm in the process of replacing it now. A 12V motor will be added to the list improvements that go back in. (One new fire extinguisherhas been added as essential equipment to carry around. It should be easier to explain that a spare pair of pants.)
George0 -
I think they came with a 15A fuse for the 6V heater fans, but double check this. My car has been converted to 12V and I just run the fan on "Slow" all the time. No probs so far, but the heater switch know does get a little warm now and then......Guess I better stash some spare pants under the seat too.........Good Luck, Bob0
It's no wonder why more and more states are requiring vehicle inspections. Why anyone would risk their life, those of others and their cars by driving them in an unsafe condition is beyond me.0
Yeah, that's what we need...more of da Guv'mnt protecting us from ourselves.
With that mentality, the Man could dictate that I can no longer drive my Hudsons because they don't have computer controlled airbags and other supplemental restraints.... for that matter - restraints - thereby endangering my life and anybody who happens to be riding with me. Or the EPA could restrict the use of all vehicles that do not meet the ULEV standard, because the emissions from my Twin H is endangering the well being of the chick driving the Honda Civic behind me.
Don't get me wrong...I'm all for everyone having safe, insured vehicles - but it's all about personal responsibility - not Uncle Sam collecting another tax.
Mandated state tax inspections do not work. I had no problem getting my '78 Olds inspected 5 years in a row with holes in the floor and no catalytic converter.0 -
Have any of you installed a wiring panel on the interior firewall and eliminated/moved all the wires going to the switch in the dash?
I was thinking about this as I was tracing all the wires to return the brake lights to the OEM diagram when removing the broken turn signal unit (new unit does not use the brake light circuit).
I was thinking a "modern" fuse panel type wiring panel could be easily installed, better labeled etc.....0 -
any one no of a 12 volt motor that is correct to replace a 6 volt heater motor on stepdowns
thanks steve0 -
Some previous owner converted my '51 Hornet to 12 volts, which I felt was unnecessary. Converted it back to 6 volts and everything works fine now! But, 6 or 12 volts, the condition of the wiring is the most inportant.0
Well, you know how it is, some people just like to do things for the sake of doing them. But you're right, nothing wrong with a 6 volt system as long as the wiring and connections are in top shape.0
I still like my 8 volt system. No changes to make, less amperage on the wiring and brighter lights, faster starting. win win IMHO. Now I would like to get an 8 volt alternator single wire.0
If your starter, lights and heater motor aren't 8 volts, I'd think their lifespan may be shortened.0
yeah, I don't have any problems with my 6 volt.0
Dave53-7C wrote:If your starter, lights and heater motor aren't 8 volts, I'd think their lifespan may be shortened.
That statement is true, if we still drove them everyday! They may only last 25 years instead of 50! All joking aside, The 6 volt headlight bulbs say right on them 6-8 volts. I have ran 6,8, and 12 volts. I personally don't like the 6 or the 8 volt. I had to turn up the voltage regulator to get the 8 volt battery to charge. I generally lost a headlight every other year or so, depending on the brand. Tung Sol is the worst lasting and the easiest to find when it comes to 6 volt bulbs. I switched to 12 volts last year and am very happy with it. I live in the D.C. metro area and prefer the brightest lights possible so the idiots on the road can see my tail lights and turn signals. It starts up nice and quick also. I can use/ hide modern 12 volt accessories now without having to have a battery in the trunk or one of those stupid 6-12 converters that have a hard time powering a decent radio unless you spend a mint on one. I can eliminate some of the spare parts that I used to carry because of the availability of bulbs and other 6 volt parts. 12 volts being HALF of the current than that of a 6 volt system means that my Rhode Island harness barely has to work to pass the current to my accessories. 6 volt positive ground systems were adopted from the British back then. They weren't a good system then, and still aren't. Suitable? YES. Efficient? NO. A lot of the vehicle manufacturers had already gotten away from or were working towards it while Hudson was shoving them down the assembly line. Some of the cars left the showroom floor with the grounding cable tightened up to the nicely painted engine block. Ask Wayne Wherle about that. He had problems with his convertible since he bought it in late 1954. IT ALL BOILS DOWN TO HOW MUCH OF A PURIST YOU ARE or HOW CHEAP you are. A lot of Hudson folks want to get by as cheaply as possible and use their 50+ year old harness and maintain a 6 volt system. When that no longer works, they step it up to 8 volts. It generally all ends up to an under dash fire and smoke rolling up from something. ANY system is good when properly maintained, but if anyone still has an old ratty original wire harness in your car that has electrical tape all over it, YOU DESERVE WHAT YOU GET.0 -
bartibog1 wrote:
why not just run it at double speed?any one no of a 12 volt motor that is correct to replace a 6 volt heater motor on stepdowns
thanks steve
7XPacemaker wrote:
rather than going to 8v, so many stick 12v in to mask over the 60 years of corrosion and frayed insulation. a dead short at 12v isn't really any better. maintaining the system is the key.A lot of Hudson folks want to get by as cheaply as possible and use their 50+ year old harness and maintain a 6 volt system. When that no longer works, they step it up to 8 volts. It generally all ends up to an under dash fire and smoke rolling up from something. ANY system is good when properly maintained, but if anyone still has an old ratty original wire harness in your car that has electrical tape all over it, YOU DESERVE WHAT YOU GET.0 -
Going back to the original post, the problem appears to be that the person installing the voltage-dropping resistor didn't appreciate the fact that it gets HOT! One has to mount such a device in a way that won't threaten nearby components. I mount the heater resistor inside the blower housing, fastened by a brass "strap" to the metal of the housing, so the heat will be transferred to that structure. By the way, the motor draws about 6 amps in the "high speed" mode. And to qualify a comment posted above, a device will draw about half the current in a 12v system IF that device is designed to operate on 12v. A 6v device connected to 12v will draw double what it draws on 6v.0
Park,
I want to thank you for the information contained in your post. This thread has been running for a few days and you are the only person who actually answered the question posed. There have plenty of comments about 6V vs 12V vs 8V and what kind of motor should be used. With your data I can make the heater motor run reliably and the whole system will be fixed when the rewiring task is complete. Thanks again.
George0 -
Nice attitude. Sorry that the rest of us didn't snap to it and answer you in a manner and timeframe that suited you. I, perhaps like others, just didn't have the answer. Maybe someone had the answer but didn't want the possible liability associated with your use of it. So what's your point? Should we shut up and not comment?0
maybe dennis g can PM Park W directly next time with his questions.
I know my hudson has never been on fire.
anyway, thank you Park for the response. nice informative picture to boot!0 -
By the way, in case anyone's puzzled by that photo, with the wire branching out into two wires before going into the resistor, it's actually two resistors wired in parallel. The optimum resistor is a 1 ohm, 50 watt rated one, but they're hard to find. I used two 2 ohm resistors of 25 watt rating. Wired in parallel, they provide 1 ohm resistance and a 50 watt power capacity (the resistors will be dissipating about 40 watts with the engine running and heater control in the "high" position ... dropping 7 volts, with 6 amps current. 7 x 6 = 42 watts).0
After reading Park's earlier post I starting looking through my own library for power resistors. I found a 1 ohm 50W resistor in a 2005 Mouser Electronics catalog for $3.19 ea. They are probably a few cents higher now. I know from my own experience that they are a good source for commercial grade electronics. Their phone number is 800 346 6873 online catalog www.mouser.com. I hope this data makes someone else's search for power resistors a little easier.
-- Yes, I should sent Park a PM with my thank's. Sorry
George0 -
Dennis, I'll accept the thanks indirectly, via your post above! LOL. Now if we could just find a good general purpose 6v relay, with contacts rated at 30A and having four terminal connections (i.e., the operating coil not "internally grounded"). NAPA used to make one, and considered reintroducing it a few years ago, but didn't do so. I've been unable, so far, to find a suitable one. Needed for use as overdrive relay and other purposes.0
Park,
I am a retired electrical engineer. I may have some sources for components you have not explored. I'll start running the traps tomorrow to try an find such a relay. If I can't find one I'm sure I can design a solid state relay that will meet the requirements. I'll contact you via email with my search results when I have an answer.
George0 -
Dennis ... I'm an EE by education, but never worked in that field except at the supervisory level. I learned "the real stuff" from earlier days as an aircraft electrical systems instructor plus moonlighting doing electrical analysis and repair at a local garage. The later EE classes did explain some things at the "exotic level" that I'd not understood before.
The relay needed is one suitable for automotive use, an SPST with (ideally) screw or 1/4" blade terminals and a mounting tab, with cost under $20. The 12v "small black cube" types found at the auto stores, often in the "add-on driving lights and fog lights" section, are good examples. I've regularly Googled for such relays, but with no success yet. E-mail me at hetpwald@comporium.net (remove the "het" for actual address). Park0 -
Park W wrote:
Park, normally i would defer to your expertise in things electrical, but a DC motor with everything constant but doubling the voltage should have the same amp draw but run at approx double speed. I understand that a fan will not necessarily run a linear relationship as the effects of speed are seen. we take advantage of this when testing our equipment (which does respond just about linear) as you can get a better sample at the lower speed and can make easier observations. As for the disadvantages on the brush life at the higher voltage you could expound; of course if the amp draw greatly increases, the windings may not be very forgiving.By the way, the motor draws about 6 amps in the "high speed" mode. And to qualify a comment posted above, a device will draw about half the current in a 12v system IF that device is designed to operate on 12v. A 6v device connected to 12v will draw double what it draws on 6v.0 -
Nick, I have to disagree. Your explanation would apply pretty well to a series-wound motor such as a starter, but is not the case for a typical heater blower motor. You don't have the substantial "reverse EMF" to limit the current in this type motor. And it's really the current that makes a motor or any other electromechanical device operate. So, in your example, why would the motor run faster if the current were the same?0
Park W wrote:
Park, (by the way I'm an ME, so I may be well off base here) two things from my limited knowledge of DC motors and I wasn't aware that there were types where it wouldn't apply. voltage is more/less proportional to voltage and current is more/less proportional to torque. the two are independent of each other. so basically with the same torque requirement, both will draw the same current though one would run faster. so there is an increased horsepower but not current draw.Nick, I have to disagree. Your explanation would apply pretty well to a series-wound motor such as a starter, but is not the case for a typical heater blower motor. You don't have the substantial "reverse EMF" to limit the current in this type motor. And it's really the current that makes a motor or any other electromechanical device operate. So, in your example, why would the motor run faster if the current were the same?0 -
Surely you jest.0
Park W wrote:
no, the response is based on actual experience. I am interested enough now to do some testing. later this week, i'll hook a fan to a variable voltage source, ammeter and tach. I will let you know what I find.Surely you jest.0
- 183 The Flathead Forum
- 611 Vehicles
