Transmission
Hello gentlemen,
I am trying to locate a transmission part for a 1925 Hudson Super Six sedan. In the course of getting my multi-plate clutch rebuilt, on inspection of the transmission I found excessive end play in the main shaft. On removing the rear bearing cap I discovered lots of bronze shards...it appears that the main shaft rear bearing thrust washer has worn away to nothing! Does anyone have a spare lying around or know where I can get one? Failing that, I can probably get one made but I'm not sure of the dimensions? Hoping one of you fine gentlemen can assist.
Roger Bull (U.K.)
Sent from my iPad
Roger Bull (U.K.)
Sent from my iPad
