Fuel Supply Question
My '26 seems to be having a problem getting fuel. This one really
baffles me! I went through the entire fuel system(including carb)and
cannot find an obstruction. Here's the deal. I have an electric fuel
pump fitted on this car. I use the fuel pump to prime the carb for
easier starting (I have an on/off switch). The car will run for a few
minutes and then will stall. I repeat the process and it will run for a
minute and stall. I know that this car is has a vacuum tank. This is
the only part that has not been looked at. The only thing I've done is
checked the inlet/outlet lines to look for an obstruction.Can someone
tell me how this system works and what could be causing this problem.Is
it possible that this tank has an air leak? My window wiper system is
tapped into this tank and is working fine. Nothing is more frustrating
than to nurse a vehicle home that is starving for fuel.
