Re: [HSS] Troubleshooting the starter
Aaron, there are probably two things you need to do. The starter contacts
wrap around the insulated bushing on the shaft, and there is a tapered brass
plug on the end of the shaft that moves in between the contacts and makes
the circuit for the starter. The curved contacts may be worn, or burnt
through, and the tapered plug may also be worn, and so not making enough
contact. You need to remove the shaft, and the switch, and probably rebuild
them. the switch contacts can be made out of strip copper, cut and shaped
to fit. I actually cut a section out of a coper pipe and used the material
fromt his to form the new contacts. If the tapered contact plug is worn,
you can reduce the outside diameter of the insulating sleeve byt putting it
on a bolt and spinning it in a drill press or lather, and rubbing the
outside with emery cloth. To remove the shaft you need to remove the
clevis, undo the locating screw for the drive gear, and slide the whole
thing out rearwards. Not the easiest of tasks, compared to the Bendix drive
used on the Essex and later models.
Good luck,
Geoff.
Good luck,
Geoff.
----- Original Message -----
Sent: Wednesday, September 05, 2007 5:01 AM
Subject: [HSS] Troubleshooting the starter
> Everything is going well with getting my 29 Town Sedan back on the
> road. The engine is all back together, repaird accessory shaft in
> place.
> I am having an issue with the starter. Nothing happens when I push
> the starter pedal. When I bridge across from the battery connection
> to the starter post, it spins just fine. When I have my kid push
> the pedal and I bridge across, it will turn the engine over, but
> then when I remove the bridge, the pedal sticks, the engine keeps
> turning over and I have to go pull it off the floor. Here are my
> assumptions:
> 1. The post that bridges the contacts under the starter, is not
> making good contact (I did clean it).
> 2. When I bridge across with the pedal pushed down, it forces the
> current through the poor connection.
> 3. I am missing a spring/the spring is not strong enough to pull the
> pedal back to disengage the small drive gear.
> Any thoughts on how to make the starter work better? Should I
> squeeze the contacts together or coat them with something?
> Aaron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.485 / Virus Database: 269.13.5/989 - Release Date: 4/09/2007
> 5:54 p.m.
