Important Brake Adjustment
Gang,
For the past few months I have been fighting a problem of excessive
pedal effort required to stop my '29 Sedan. I have checked the drums
and shoes, adjusted the wheel adjusters, adjusted nearly all the
clearance out of the rods, repositioned the actuators, and everything
else you can think of, to no avail. I finally found the problem
today. Where the torque tubes pass through the framerails, there is a
steel plate, with three rollers that support the tube. The third
roller is adjustable. If this third roller is not adjusted so that it
is completely contacting the torque tube, then X percentage of brake
pedal effort will be expended walking the tube around inside the frame
holes rather than twisting the tube properly and applying torque to
the brake rods. You would not believe the difference this adjustment
makes in brake function, it now feels like power brakes. Next time
you're under your Hudson, check the adjustment of this third roller.
If it is backed out even the slightest, you're not getting 100%
braking efficiency.
Best Regards,
James Coats
Persistent Hudson Enthusiast
braking efficiency.
Best Regards,
James Coats
