Re: [HSS] 1928 Hudson ( Super six ) torque for the Main Bearings a
I hope someone's keeping an archive of all Geoff's
knowledge and wisdom - it would make a fabulous "lucky dip" of Super Six
information.
information.
Cheers...... Peter R.
----- Original Message -----
Martyn
Hudson
Martyn
Hudson
Sent: Tuesday, January 23, 2007 12:47
PM
PM
Subject: : [HSS] 1928 Hudson ( Super six
) torque for the Main Bearings and connecting rods
You live and learn after so many years another obvious answer I did not
know about.
At 19:54 23/01/2007, you wrote:
Because there is
nothing that would stop the studs from unscrewing from the block.
- ----- Original Message -----
- To: HudsonSuperSix16- 29@yahoogroups. com
- Sent: Tuesday, January 23, 2007 8:08 PM
- Subject: RE: [HSS] 1928 Hudson ( Super six ) torque for the Main
Bearings and connecting rods- Geoff
Why use twisted wire & not split pins for the main bearing
studs?
Cheers- David Y
- New Zealand
- -----Original Message-----
mailto:HudsonSuperS ix16-29@yahoogro ups.com] On Behalf Of
GeoffClark
Sent: Tuesday, 23 January 2007 19:53
Subject: Re: [HSS] 1928 Hudson ( Super six ) torque for the Main
Bearings and connecting rods- The problem is that you have align the castellations of the nuts
with the holes int the bolts and studs, so you have to have a starting
point. For the connecting rods, do up to 35 lbs, and then
tighten further until the holes and slots align. For the mains, do
to 60 lbs, and then tighten further to align. Do not back off the
nuts to get the holes right, and remember to use wire between the main
bearing studs, and twist together (not split pins).- Geoff.
- Sent: Tuesday, January 23, 2007 1:33 PM
- Subject: [HSS] 1928 Hudson ( Super six ) torque for the Main
Bearings and connecting rods- Hi:
- Please inform me the pounds of torque for a 1928
Hudson super six motor for the Main Bearing and the connecting
rods.
- Hudsonly yours,
- Enrique
- No virus found in this incoming message.
- Checked by AVG Free Edition.
- Version: 7.5.432 / Virus Database: 268.17.5/645 - Release Date:
22/01/2007 4:10 p.m.
This message has been
scanned for viruses and
dangerous content by IC-MailScanner, and is
believed to be clean.
For queries or information please
contact:-
Internet Central Technical Support
http://www.netcentr al.co.uk
