Re: [HSS] Re: Marvel Carb
Just one small point I should raise, and it may depend on what is classified
as "varnish". In fact the original cork floats were coated with shellac.
Varnish is usually a linseed oil based product, whereas shellac is is made
from gum dissolved in methylated spirits, or ethanol. Probably a better
way to go would be to use a modern two-pot coating, such as Epiglass
Everdure which is mixed with a hardener, and chemically hardens. This is
impervious to gasoline, and with increaseing use of Ethanol in modern fuels
we have to be one step ahead.
Geoff.
Geoff.
----- Original Message -----
Sent: Saturday, November 25, 2006 1:33 PM
Subject: [HSS] Re: Marvel Carb
> Tim,
> I am one of the few people stateside that fool with Marvels. They can
> be tricky. Your answers are listed below:
>> - The cork float seems to coated with something. Is that old gas
> or some type of shellac or other coating?
> The float is coated with varnish. This keeps the cork from
> absorbing the gasoline and disintegrating over time. If the coating
> is intact, and the float isn't chipped or rotten, and still floats,
> there's nothing wrong with it. If necessary you can make a new float
> and coat it with varnish, reusing the lever from the original float.
> The floats were originally cork. In my car I have a brass float which
> came in a parts carburetor I bought, presumably from an ancient
> rebuild kit.
>> - I am guessing gasket sets are not available. Where can I get the
> thing gauge gasket material to make hnew ones?
> Gasket sets are difficult to find. You will need the carburetor to
> heat riser gasket, which is available from Dale Cooper
> www.hudsonmotorcarco.com, and is a copper faced gasket. The gaskets
> on the carburetor you will need are the float bowl cover gasket, and
> the float bowl to carb body gasket. The best way to make these is to
> take an ink roller made for inking stamp pads, and roll it about the
> surface you need the gasket for. Then stamp the part onto the gasket
> material, and you'll have a positive of the gasket you need. Then cut
> it out. I use the thin, black rubber-fiber or rubber-cellulose
> material which can be found at most auto parts stores. If you can
> find a Fel-Pro Part no 3060, it is a pack of assorted gasket materials
> that is very handy. Be very careful when working with the die cast
> float bowl; it is made of chocolate. On my carburetors I use a VERY
> THIN bead of RTV on the flange at the bottom of the iron carb body
> where the float bowl attaches, because the float bowls are ALWAYS
> warped there, and if you tighten the screws too tight you'll break
> everything. Use Permatex Ultra Black, as it won't soften or dissolve
> in gasoline, and use sparingly.
> If your float bowl goes to pot, you're not totally S.O.L., as our very
> own John Meadows casts new ones with covers out of silicon bronze.
> These are the way to go! He can be contacted at meadows@dcsi.net.au .
>> -The float bowl cover has a corner missing. All screw tabs are
> intact;It looks like it will still seal the bowl. It is the right
> corner that faces the air horn. A passage with a with a split tip
> shaft protrudes through the cover on a diagonal from the bottom of
> the bowl through the bowl cover. Where the shaft goes through the
> cover is where the cover is broken. Is this critical?
> I have a number of these that are like this, and it may lose a small
> amount of gas on a hard stop or corner, but I wouldn't worry about it.
> Again, the ultimate fix are John's bronze ones. The shaft you
> mention is the metering pin, which controls the flow of fuel to the
> intermediate and high speed jets. It must be free, straight, and
> properly connected to the throttle valve located in the heat riser.
> The jet that it fits inside at the bottom of the float bowl must be
> clean as well.
>> - What else should I be aware of?
> I think just what I've mentioned above! When you put things together
> just be very careful with that float bowl. If you are uncomfortable
> rebuilding that carb, send it to me and we'll make it as good as new.
> Geoff Clark also does them, out of NZ. I believe Dave Kostansek
> still does them as well, he is in the club directory under Ohio.
> There are at least two pamphlets on the Marvel in existence, one is
> the operation manual for the carb and heat control used on 29 Hudsons,
> and the other is entitled "Carburetion in Relation to Service / How to
> Overhaul a Marvel Carburetor". I believe Alex Burr has these, you can
> contact him by looking him up in the Members section of the Yahoo
> Groups website.
> Best of luck, please e-mail with any questions.
> Best Regards
> James Coats
> Coats Classic Cars
> Birmingham, AL
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.430 / Virus Database: 268.14.15/550 - Release Date:
> 24/11/2006 5:20 p.m.
