Re: [HSS] A Couple Of ??
There is a thin gasket between the adjusting flange and the crankcase, and
between the flange and the bronze housing. You need a wire to carry 30
amps. Anything less will cause heating and voltage drop. I'm not sure of
the wire gauges you use in your country. Here they are marked in amperage,
15 or 30 usually. As a rule - "If in doubt, fit a heavier wire than you
think you will need".
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, August 30, 2006 2:53 PM
Subject: [HSS] A Couple Of ??
>I am getting a oil leak from around where the adjustment plate bolts to the
>motor where you can adjust the timing chain. I had this apart many years
>ago when I had the water pump/generator shaft out for repair and not sure
>if there is some type of seal in there ? Please advise. And, what size wire
>to use to replace the charging wires from the generator to amp meter to
>battery ? Thanks, Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.405 / Virus Database: 268.11.7/432 - Release Date: 29/08/06
