Re: [HSS] Re: Timing Gear for Hudson 6-40
I've had no experience with the 6/40, but I restored a '22 Essex Four, and
it had an alloy cam gear, which was not noisy at all. Also the later Hudsons
from 47-52 8 cyl. models all came out with alloy gears, which could be
retro-fitted to the earlier models. It would be a good idea to make these
replacements out of alloy instead of fibre.
Geoff.
Geoff.
----- Original Message -----
Sent: Tuesday, July 25, 2006 1:29 PM
Subject: [HSS] Re: Timing Gear for Hudson 6-40
> Jim I'd be interested in a spare. I'm thinking you mean the front gear
> on the crankshaft? Does yours have a monoblock or 2 3cyl blocks? Did
> the fiber fail? I thought mine 16 was metal with one diagonal toothed
> surface that drove both the cam and the accessory drive. I'd like to
> see the pictures. I'll have to see if I can find my pictures from last
> time I had mine apart. Thanks Jerre Hoffman
> --- In HudsonSuperSix16-29@yahoogroups.com, "jimryan15" <jkryan15@...>
> wrote:
>> I need a fiber timing gear for my 1915 Hudson 6-40. This is a
> helical
>> cut 60 tooth gear with a pitch diameter of approximately 7.25
> inches.
>> Although the gear is fiber, the hub is steel, as are the two outside
>> surfaces of the gear. If I cannot find one, I am going to have one
>> made. Producing more than one reduces cost, so if anyone is
> interested
>> in having a spare for their car, please let me know and we can work
>> from there. I have pictures of the gear if you would like to see it.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
