29 H. Landau/Club Sedan For Sale...
Folks,
Take a peep at this: http://www.prewarcar.com/searchresults.asp?make=Hudson
They're calling it a '30 but it's obviously a '29. The main photo is taken
at a tricky angle and there's no useful info provided. I can't"see" the
other photos, for some reason, so I can't tell whether it's a Model R Landau
or a Model L Club Sedan. Do we know this car?
I have to say I'm underwhelmed by these dealers who put up such a
sophisticated front, ask lots of $$ and clearly haven't done even the most
basic research.
Having said that, the asking price of about US$35k for what looks like a
really nice car tends to put some other wild speculation about prices in
perspective, doesn't it?
Cheers.......... Peter R.
basic research.
----- Original Message -----
Sent: Wednesday, January 18, 2006 5:43 AM
Subject: [HSS] Re: Another wacky idea....?
>A nice - and not wacky - idea Lew, but I have another solution to
> the problem of vacuum tanks running dry when I forget to close the
> shut off valve. It's this. I've installed an electric fuel pump in
> the main fuel line just after the fuel tank but BEFORE the OEM
> vacuum tank. (It's quite easy to bolt a plate to the bottom of the
> chassis near the diff. and mount the pump on this). This pump is
> wired up to a spring loaded toggle switch hidden behind the dash
> board so that it will only operate when this switch is held down.
> Now, usually the vacuum tank operates like it should, and one would
> want it to, drawing petrol straight through this electric pump, and
> on to the carb. But, should the vacuum pump ever run dry, then I
> only have to depress this toggle switch for about a minute, the
> electric pump kicks-in, pumps petrol up to the vacuum tank and I'm
> motoring again.
> With this solution, one wouldn't have the continual draw of 2.5 amps
> the entire time the car is running which, as you say, might be a
> problem for folk like me who still run their cars on their original
> generators. Electric petrol pumps also have a wire mesh filter in
> them which is a good thing to have before a vacuum tank. These can
> be cleaned too and every year or so, I screw the filter out, rinse
> it in petrol and put it back. Better I think than totally replacing
> paper ones.
> Incidentally, I set this system up when I first restored the car
> because I then didn't have much faith in vacuum pumps and wanted an
> electric fuel pump in place as a back-up. That was some twenty years
> ago. Now, in that time the vacuum pump has never failed - it's only
> me that has done this when I forgotton to turn off the shut-off tap!
> Brett of Hudson Hire
> --- In HudsonSuperSix16-29@yahoogroups.com, Lew Phelps
> <hudsontownsedan@e...> wrote:
>> Since Geoff Clark refitted my '29 Town Sedan with the OEM vacuum
>> tank, removing an electric fuel pump, the engine has been very
> happy,
>> except for one thing.
>> If I leave the car parked and not running for an extended time
> (say,
>> 24 hours) the carb float isn't quite strong enough to shut off
> the
>> flow of gas from the vacuum tank, and thus eventually the
> reservoir
>> in the vacuum tank will drain out, and you're out of gas, at least
> as
>> far as the engine knows.
>> Geoff and I installed a little shutoff valve on the line leading
> from
>> the gas tank to the carb, and that works fine -- when Cathy and I
>> remember to turn it off when we park the car in the garage. All
> too
>> often, we have come out to the car to find that the vacuum tank
> is
>> dry. I have become VERY adapt at refilling the tank without
> taking
>> the top off of it (details to follow, if anyone is interested).
>> Anyway, after this happened again yesterday, I thought that a
> good
>> solution to the problem might be to locate and install a suitable
>> solenoid valve (that is, a shutoff valve that would automatically
>> shut off when you turn off the ignition, and open to let gas flow
>> when you turn the ignition switch on.
>> It turns out that suitable valves ARE available, with 6-volt DC
>> coils, at a cost of about $35 each. The coil draws 16 volt-amps,
>> which means it draws 2.5 amps the entire time the car is
> running.
>> This might be a problem for anyone with an OEM generator and
>> additional electric load above and beyond the headlights, tail
>> lights, etc. I have converted to a higher-amperage generator
> (50s
>> era Hudson unit) so it's no problem for me.
>> So the question is....anyone else interested in ordering one from
> the
>> online supplier? I will aggregate orders, and then reship to
> each
>> user if you wish.
>> Alternatively, since this is a possibly wacky idea, maybe I
> should
>> order one valve, install it, and test drive to make sure it
> functions
>> as intended -- that is, that it actually stays in the "open"
> position
>> whenever the ignition is turned on.
>> Let me know what you think.
>> Lew
>> PS: if you happen to inadvertently drain your vacuum tank, I
> have
>> found that it's pretty easy to refill as follows:
>> 1. Procure a funnel with a flexible plastic hose on the end. I
> use
>> one from Pep Boys that has a shutoff capability built into the
> funnel
>> itself, which is very nice, because you can pour a pint or so of
> gas
>> into it, position the tube, and THEN start the gas flow, at a
> very
>> controlled rate by only slightly opening the funnel valve..
>> 2. procure an extra brass fitting, identical to the fitting that
>> attaches your gas feed line from the gas tank into the vacuum
> tank
>> (mine is a brass fitting for copper flare style coupling).
>> 3. Remove the line leading from the tank where it connects to the
>> vacuum tank.
>> 4. screw on the identical brass fitting, "bare,"
>> 5. Fill the funnel with gas; presss-fit the plastic hose onto the
>> tapered end of the brass flare fitting, and open the valve on the
>> funnel. (The vacuum tank will take about a quart of gas, and it's
> a
>> good idea to pretty much fill it up with this process, to ensure
> that
>> there's enough gas to refill the carb, the line running to the
> carb,
>> and leave enough in the vacuum tank to allow it to function.)
>> 6. Remove the extra fitting, replace the connection to the gas
> tank,
>> and start the car.
>> Lew
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
