Re: [HSS] Re: Valve Tappet Adjustment ?
I have covered this topic many times, including an article in the W.T.N.
Basically, you need to follow the firing order 153624 to do it easily and
quickly. Wind the engine over until No. 1 valve is fully open. In the case
of the F-head Hudsons (late'27-'29) this is the inlet. You then adjust it's
opposite number, that is No. 6 inlet valve. There will always be two
valves fully open at the same time, one inlet and one exhaust, in the front
and rear valve chambers alternatively. So you check which exhaust valve is
open at the same time as No. 1 inlet, and adjust it's opposite number in the
rear section of the valve chamber. Having done that, you wind the engine
over 1/6 of a turn, watching No. 5 inlet valve to open fully, and adjust the
two relevant opposite valves. By the time you have wound the engine over
one complete turn you have adjusted all the tappets. An easy way of
figuring which valve to adjust is to number them thus as if you are looking
unto the tappet chamber - 123456 654321 the first set of numbers being the
rear half of the engine, and the second set the front. Thus whichever two
valves are open, you just count and adjust the same number in the other end.
Another point - on the '29 Hudsons, which have offset rockers, check the
clearance at the valve end of the rocker, not the push rod.
Geoff.
Geoff.
----- Original Message -----
Sent: Thursday, July 28, 2005 1:03 PM
Subject: [HSS] Re: Valve Tappet Adjustment ?
> Ron,
> You will need to remove both side covers and the valve cover. The
> gaskets on the side covers are a sheet-type and usually come off
> intact, making replacement unnecessary. You will probably need to
> replace the valve cover gasket, however. Measure the clearance at the
> valve stem, by rotating the engine: When the intake valve just starts
> to open, check & adjust the exhaust valve clearance. The adjustments
> are made inside the side cover on the end of the pushrods. Then
> rotate until the exhaust valve is completely open and just beginning
> to close, and adjust the intake valve. This will position the
> followers on the base circle of the camshaft where adjustment can be
> properly made. You may want to remove the spark plugs as this will
> make rolling the engine over much easier. Also, a hand crank helps.
> Best Regards,
> James Coats
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
