Re: [HSS] Dual Side Mounts ??
As far as I can ascertain, the well was the same size for long and short
wheelbase cars. Indeed, they used the same guards (sorry fenders for you
gringos!) on both series, the only difference is that the mounting bracket
is swapped from side to side, so the bolt holes are in different positions,
as the headlamps sit further back on the long wheelbase cars. The wheel
size was 600 19" for short wheelbase and 600 18" for l.w.b., with all l.w.b.
cars having wire wheels, and optional for s.w.b. along with wood spokes and
split rims. They use the same clamp, which does have a padlock (made of
unobtainium). I have one original padlock, and have made a swivel cover for
the other side with "Hudson Super Six" etched on it. I can get a clamp cast
for you if you like, out of bronze. Some of the tyres (tires!) available
today, are too large to fit the well. For instance, I have Lester 650 19's
on my '29 7 passenger sedan, which has wood wheels instead of the original
wires. These give a good gear ratio, as they are a huge diameter tyre, but
if I have a puncture I have to leave the tyre deflated to get it to fit the
well, as it is too fat. The original 600 18's I had on my first 7 passenger
sedan fit the well real good, as do the 600 19's on the spare rims of my
current car. It would not be too hard a job for a good panel man to make up
a wheel well, and the stay is also a pretty easy engineering job. If not
this would have to be manufactured as well. But certainly easier if you
can find another with the well aready there. The side bracket would be a
bit trickier to cast, but could be done. Do you have the threaded moulding
mounted to the bulkhead? Good luck,
Geoff.
Geoff.
----- Original Message -----
Sent: Sunday, July 17, 2005 2:58 PM
Subject: [HSS] Dual Side Mounts ??
> My 29 was, I believe a dual side mount car. The driver side fender was
> replaced without the spare tire well. There is the hole in the side cowl
> and I can see the outline under the dash where the mount was along with
> the bolt holes thru the fire wall. Now the question is does anyone have a
> fender with the spare tire well for sale along with the mounting hardware
> ???? I am also missing the lower hold down for the spare tire I do have on
> the passenger side if someone has this for sale. Do these have locks on
> them ??? Also, was the wire wheel the same as the wooden wheel well size
> and mounting hardware ? I know, Good luck on this one. Dont know unless we
> ask I always say. LOL Thanks Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
