Re: [HSS] 29 Gas Gauge Situation
I was just wondering. I believe the Essex sending unit is the same. I used the Essex information to give the price. When I talked to them about the Essex one it was an in stock item. I wonder if they did not recognize the similarity and quoted a price for a newly designed part. Might be worth the question
Lewis Mendenhall
---- Hudson29@aol.com wrote:
Lewis Mendenhall
> I just checked with Atwater-Kent in MA about the gas gauge sending unit for
> the 1929 Hudson. I had expected a $95 price and was shocked to be quote $450 &
> 4 weeks mfg. time! The unit they would make would be authentic down to the
> cork float. Nice as the sending unit sounded, it was way outside of budget and I
> had to decline.
> Another option was offered. If I send them the old unit, they would use it as
> a pattern to make up a non authentic but workable sending unit. The price was
> $145 plus shipping and 2 weeks mfg. time in addition to shipping time 2 ways.
> This method would work, but still seems like a lot of expense and downtime.
> The unit I took out was modern with plastic bits including something that
> looked like a compressed foam float. Mechanically, it work fine, but what of it
> electrically? I have no idea where it came from and no reason to trust that the
> previous owner had even the slightest idea that he knew what he was doing.
> While the gauge on the dash did not indicate correctly, I don't know where
> the fault lies. How can I test the sending unit? I have a volt/ohm meter that I
> use to test batteries. How should it be set up and what indications would be
> good for test purposes?
> Paul O'Neil
> SoCal
> 1926 Hudson Anderson Coupe
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in here?)
> www.cichet.us
> www.aeromark.net
