Re: [HSS] Shauns 28 Essex
micsha_nz wrote:
****There is no standard air cleaner. originally there was a hot air>
> My '28 2-door coach finally arrived yesterday. Started up first time
> on the transporter, reversed off and then up the drive to the
> garage. A thorough inspection post delivery then a drive to the
> petrol station for fuel and a couple of times around the block to
> ensured that everything worked OK. The odd bit of blue smoke
> indicated that the engine needs some work, but otherwise all was
> mostly OK. However, two things turned up which some of you may be
> able to help me with:
> - there is no air cleaner sitting at the air intake of the carby.
> Has anyone ideas on what type/model I am supposed to have ? Photo of
> RHS engine bay is posted in the photo section under NZ '28 Essex.
> Note that my '28 is a Right Hand Drive. Steering box seen a bottom
> left.
stove surrounding the exhaust manifold, with a curved pipe going up into
it, and couple of doors which opened to allow cold air in. A small
accessory air filter will do the job okay, but make sure you don't
restrict the airflow too much or economy will be affected. The Stewart
carby is a very reliable unit, but neds as much air as it can get.
>***Sounds like the flange off the universal dust cover has come loose.
> - there is "ring" (approx 3 inch dia. chamfered) loose around the
> driveshaft. I presume it should fit around the rear universal
> fitting. The diameter is approx 1/4 inch larger to the rear as
> opposed to the front. There is a square notch in the internal
> surface. However, I can't figure out how it attaches. Has anyone any
> ideas? Again a photo of the rear driveshaft is posted in the Photos
> section in the NZ '28 Essex folder.
>Do you have the resistraiton papers yet? It should show the previous
> Geoff - looks like this is the vehicle you did the suspension work on
> a couple of years ago; hydraulic shock absorbers all around, sealing
> around the front engine gaskets etc;
> Thanks
> Shaun O'Neill
owners.
Geoff.
