generator output/alternators????
OK, guys. I know I am about to bring down the wrath of somebody for
even raising this question, but I need to do so.
I finally completed the wiring job on my '29 Town Sedan, with the last
step being to hook up the headlights. I find that the generator can't
keep up with the demand. Part of the problem is that I chose to convert
to halogen bulbs, which are higher wattage than the original bulbs, but
that isn't all the problem; even with the current demand of OEM bulbs I
would be "running in the red" with headlights on. (I measured the
resistance on the filament of one of the bulbs that was in the
headlight, and found 1.2 ohms on low beam and 0.9 ohms on high beam.
This would equate to, respectively, 32 watts on low beam and 42 watts
on high beam, whereas the new bulbs draw 55 watts on low and 60 watts
on high -- 19 to 20 amps for both headlights, depending on what you
figure as "base" voltage. Even at the lower wattage of the OEM bulb,
we're looking at 10 amps on low beam and 14 amps on high beam. This
is right at the limit of the generator's "stock new" output rating of
13 amps when warm.
With the lights on low beam, I am seeing a negative current (battery
discharge) of about 15 amps, which means the generator is keeping up
with the ignition coil and a few amps worth of demand for the lights,
but not nearly enough. (Without lights on, I get about 10 amps positive
current when the car is first running and the generator is working to
recharge the battery).
Which leads me to the conclusion that if I intend to drive the Town
Sedan at night, more than briefly, I need to convert to an alternator.
Horrors!
I figure there must be a way to do this that is "non-destructive" --
that is, mount it on a bracket that will allow it to be removed and the
car restored to original condition of anyone so chooses.
I guess the main question is where to mount the alternator and where to
mount the pulley for the drive belt. It would seem that the drive
pulley either has to mount up front, driven by a larger-size belt that
would drive the fan and the alternator, or pull the generator and mount
a drive pulley in its place, possibly with a fabricated shaft that
would "mimic" the original generator mechanically.
So, for all those who have determined not to lynch me, I have the
following questions:
1. Any reason NOT to do this (that is, I'm going to burn out the
ampmeter, etc.)
2. Where to mount the alternator and the drive pulley?
3. Any recommendation on alternator brands either to get or to avoid?
I'm looking at the JC Whitney catalog which offers an 80 amp alternator
for about $80. Is that a unit worth considering?
13 amps when warm.
Horrors!
ampmeter, etc.)
