Ignition system diagnosis
With the assistance of a friend more knowledgeable than I am regarding
automotive electrical stuff, we went to work trying to figure out why I
can't start the Town Sedan these days.
When we first tested, we had a pretty good spark from the coil secondary
(lead to the distributor), but couldn't get any spark from the plug
wires. We replaced the ground wire on the distributor, which was very
frayed. Still nothing.
Then we went back and tested the coil spark again, and it was gone. Zip.
Nada. About this time, I discovered a loose screw holding one of the two
wires on the ignition switch. Tightened that. Still nothing.
We're currently focusing on an intermittently bad coil as the problem.
Thus, several questions:
1. We measure about 6,000 ohms between the negative primary side and the
secondary output, as well as between the positive primary and the
secondary output. Is that appropriate? What are the correct values for
resistance?
2. The wire leading from coil to distributor cap measures about 3,500
ohms. This is suppression wire. Is that appropriate?
3. The distributor rotor was broken and epoxied together by former
owner. Where can I get a replacement for that (and the cap, while I'm at
it?
4. Assuming I need a new coil, what's the desired replacement item? Will
any old 6-volt coil do?
5. What is the correct dwell reading?
6. Were OEM spark wires solid wires, rather than resistance wires?
Lew Phelps
Pasadena, CA
1929 Hudson Town Sedan
http://home.earthlink.net/~hudsontownsedan
resistance?
it?
Lew Phelps
Pasadena, CA
