Re: [HSS] More on mysterious engine problem
hudsontownsedan@earthlink.net wrote:
***Are you looking at the amp gauge or the fuel gauge? I don't see how>
> I think I have an electrical problem. Here's why: when I first turn on
> the ignition switch, the gas gauge reads empty. If I advance the spark
> retard to maximum retard, the meter comes alive. If I reduce the
> retard, the gauge goes back to zero. Once the car starts, I can reduce
> the retard and it runs fine, with the gas gauge staying in the "on"
> position.
the fuel gauge could act like this unless you have the input wire to the
gauge connected up to the negative side of the coil. In this
instance, when you retard the ignition the points will open, causing no
circuit to earth.
>***Could be the same problem. The input to the SW terminal on the back
> BTW, I also have a problem with the gas gauge. It reads 1/4 tank no
> matter what the gas level. Stuck float? Electrical short connected to
> the above problem?
of the gauge should be from the ignition switch. The wire from the
other side of the gauge goes back to the tank.
>***You have to remove the fuel tank to get access to the fuel gauge
> I'm setting out very shortly to do a complete rewiring of the car,
> with a harness purchased from YnZ Yesterday's Parts. If there's a
> short (and that is not improbable given the overall condition of the
> wiring), I'll fix it with that. But how do I access/remove/service the
> float level in the gas tank?
sender.
>Answers above marked***. Have you checked that all terminals are tight
> Does this provide clues to anyone?
> Lew Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
> http://home.earthlink.net/~lewphelps/hudson_29
on the iginition circuit? What voltage do you have at the coil?
should be full 6 volts. The wiring is so simple on these cars you
should be able to trouble shoot in no time at all.
Geoff.
