Re: [HSS] Valves
Calif-Hog-Rider@webtv.net wrote:
As I said Ron, I have been driving my '28 Essex exclusively on unleaded>
> Thanks for all the info...I don't care about the knocking but more the Valves burning...If you have the answer please respond.Thanks again Ron...PS..It doesent knock..LOL
since doing the motor up 18 years ago, and have not touched the it in
that time. I do around 5000 miles a year in it. I checked the
tappets last year, and they were still the same as when I did the motor.
The only trouble you are likely to experience with unleaded is with a
high compression motor driven at high r.p.m., with high valve spring
pressure, and run at high temperature. None of these criteria fit your
Hudson.
Geoff.
