Re: [HSS] 28 Rear Hub
Robert C. Harris wrote:
The grease is most likely heavy gear oil which has leaked past the felt>
> Geoff, It worked, I had a puller so I hooked it up and hit it several
> times with the sledge and the Hub popped off. Thank you for the
> advice.
> There is allot of grease between the inner part of the Hub and the
> part that retains the Bearings(around the bearing grease deflector).
> Is this normal ? Thanks again, Bob H.
inner seal. It is an easy job to replace this with a modern seal and
overcome this problem. Also the adjustment of the bearings must be
correct, as play here allows the oild to get past the seals.
Geoff.
