27 H problems
John - yes, just give the wicks for the int. valves a good squirt of
oil each time you take it out for any kind of a long drive as it says
in owners manual.
As to problem #2: I'd also check the needle & seat in your vacuum
tank, assuming you're using it. If you're using an elec. fuel pump,
that is the reason as the needle & seat in the old updraft carb.
can't hold the pressure that an elec. pump puts out. If you're using
the vac. tank & it's in good condition & gas puking out the carb.,
then float level or needle & seat not in good condition or set right.
Carter printed little books for their carbs. that give all the
settings as to heigth of float, etc., but hard to find.
Hope this is of some use,
in owners manual.
