Re: [HSS] Oil Pump Leak
Hudson29@aol.com wrote:
Paul, the only thing inside here is the steel ball valve which sits on>
> Thanks Geoff & John for your reply. This is another case where I got no reply
> on my AOL email but luckily tried the Messages section of the list home page.
> The leak does appear to be from the copper washer between the bronze casting
> and the gourd shaped bauble underneath. Does this all come apart easily, or
> should I just try tightening the nut? I really have only a dim image of what
> might be inside this unit, but at least I can get at everything now with the
> radiator still out. The top washer does appear to be nylon, not very period
> at all. Fortunately it will be mostly hidden by the distributor and radiator!
> Fullerton, California USA
the seat of the threaded portion. Remove the oil pipe, tighten the
hexagonal nut, and you will then have to re-align the bottom piece to
get the oil pipe back on. This is on a tapered thread.
Geoff.
