Motor Mounts
Attachments :
One of the items that needed to be fabricated before installing the new
'26 motor were motor mounts. When we removed the old '29 motor out of the '26
car, a set of what look to be original Hudson motor mounts was recovered. I
believe them to be original because they are very regular in appearance and
made of a tough fiber material. The parts book for the '26 mentions that the
motor mounts were a fiber material.
The originals measured 3/16" thick and are VERY tough and inflexible.
They could have offered little in the way of cushioning or vibration
isolation. It's a good thing that the counterbalanced Super Six engines ran
so smoothly!
The front mounts (the ones with the single holes) were worn down much
more than the rears and even allowed metal to metal contact between the
crankcase mounting ears and the chassis steel mounts. Replacement seemed wise.
Press Kale of K-Gap suggested using his mud flap material for radiator
mounts and that same material was used to make new motor mounts also. The
material is vulcanized hard rubber reinforced by a core of cloth. It is an
1/8" thick. While still pretty stiff, it is much more flexible that the
ancient fiber originals.
To make the new mounts, I held a sheet of material underneath the
mounting ears of a Super Six motor a traced around with a pen. Pencil made a
poor impression. The material was cut by ordinary scissors. After cutting out
a front and a rear master, the new cutouts were used to make three more front
and rear profiles. Contact cement was used to bond two pieces together into a
1/4" thick composite. Now there were two rear and two front motor mounts, but
the looked a little ragged around the edges.
To my surprise, the old bench grinder proved the perfect tool for
smoothing the rough edges. The two fronts were held together and touched to
the wheel which put a fine professional looking edge on the rubber. Both
sides look alike when separated off the wheel. The rears were done the same
way.
All that was left was to drill the holes. My biggest drill is a 1/2", the
exact size of the engine mount bolt. To make the holes, the two front mounts
were held together by hand under one of the fiber originals and the hole
bored through with a drill press. The rears were bored the same way. The
holes are a snug fit on the bolts, but that turned out to be not all bad.
When the engine mount bolts were run up from the bottom, the new rubber
engine mounts held them neatly in place.
The overall result looks pretty nice. With the stock installation, the
mounts were completely invisible. In this one, a bit of rubber shows all
around helping to support the rubber supporting the weight of the motor.
One pic is attached to this post, two have been uploaded to the Files
section in the folder "Super Six Motor Mounts." I'll shoot two more pics of
the mounts installed this coming weekend and post them to the same folder.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.com/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
so smoothly!
way.
