Grounding strap
Lance,The only difference will now be the grounding strap connects from the frame to the 12v neg. side of the battery. Your Hudson will have to be grounded either positive or negative but one leg has to connect all the non insulated side of the charge and one leg has to connect to all the isulated side of the charge.So the short answer to your question is yes. By the way the only dumb questions are the ones you didn't ask.0
