Horn just started blowing
Yes. Remove the horn button and look for a possible malfunction in the contacts under the button. It could be that, simply by turning the wheel, you caused the button's contacts to close the circuit.
Disconnect the horns themselves from the relay, before you start poking around. That way you'll only hear a click each time you complete the circuit. Either that, or wear some good ear plugs!
Probably the insulation on the wire going down thru the center of the column has all worn off in one spot. Disconnect the wire coming out of the steering column and going to the horn relay to check it. Replkace the wire and it should be O.K.0
You need to cut the old horn button wire close to the steering wheel and crimp/solder the end to a new wire. The end is a special shape to ground through the horn ring.
