Brake shoe part numbers
Your truck should have the 1 3/4 x 11 brakes front and rear, which are the same as stepdown rear.
Rockauto lists several under 54 Hornet
NAPA RS55
You might have to loosen the anchor pin and re-adjust per Walt Mordenti's instructions to make them fit better.
There are a couple of people in the back of the WTN who re-sole the shoes also
Thank you Uncle Josh0
Now if I can find Walt's Tech Vol 2 page 15 to do the work.0
Just an update, ordered the shoes from Rock Auto and they just arrived. The configuration is correct so no modification needed to lower the anchor pin.
Now I just need to make the time to go and replace them.
Thanks for your help here.
