Overdrive, 1946
paulrhd29nz
Does any one have Geoff Clarks wiring diagram to operate the overdrive from a single switch on the dash?
I want to change mine over on my truck. And while we are on the subject of over drive, Does the push / pull knob under the dash need to in?? or out?? to reinstall the solenoid?
Paul
The Old Car Manual Project has a copy of the actual Borg Warner Overdrive Manual. If you copy this url into your search window:
http://www.tocmp.com/manuals/trans/Borg-Warner Overdrive/
you should have all the info necessary.
This is the message that pops up when I click on the url. Lee O'Dell
Oops! This link appears to be broken.0 -
Try http://www.tocmp.com/manuals/trans/Borg-Warner Overdrive/index.htm for their o/d index.. I got in OK.
Dave Young
Dave
That works. Thank you.
Lee O'Dell0
