Another Brake/Clutch Pedal Question
It seems the money I spent on Hudson Manuals was a waist at this point since I cant find any answers there!! Thank goodness for you guys on the forum! The previous owner converted my hydromatic to a manual, and now I am converting back, and trying to remove the clutch pedal. Removed the master cylinder and everything attached to the brake pedal. QUESTION- How do I get the brake pedal and clutch pedal off??????? Pic attached is where I am at!
[attachment:1]DSC00419.JPG[/attachment]
Thanks for all your help
Brian
Brian
Lets try the pic again!0
Me thinks the "Gas Wrench" would work here.. LOL But I have been accused of being impulsive. You don't plan on useing them again are you?0
Well,,, I am swapping out steering columns and possibly brake pedal along with master cylinders, so possibly!! I would like the practice, so I would prefer to get it out the nice way!!!0
This is the other side connecting to the clutch pedal. Is the pin that you see actually a bolt that has miraculously lost its head, or an actual pin??0
I have only worked on r.h.d. cars, but to me it looks like you need to drive out that taper pin from the hub to get the pedal arm off.0
Well the pin didn't work and I got a little IMPULSIVE- Thanks Dave- so I just ended up cutting it off!!!!
thanks for the suggestions guys!!
Brian0
