TWIN-VORTEX Aluminum Head
As of 2-10-11
The Joint Venture between Me,Rudy Bennett and Chuck Fellows with Empire Motors in building the Twin-Vortex Aluminum Cylinder head has ended.
Chuck and I will be testing one of the heads along with Randy Maas testing one also. When the testing is completed we will report back to the Hudson Forom and each of you that bought one.
The heads that each of you recieve will have Added aluminum inside to give a little more strength in higher C.R. applications. The #1-#6 spark plug holes will be aligned better to match all of the others,as per talks with Empire Motors.
Chuck and I believe that the Improved Head will be the best head ever built for the Hudson 6-cylinder engine built for 1951-1956 wide block 232-262-308 engines.
Empire Motors said that all orders will be filled by the emproved Cyl head.
The head that we and Randy has are proto types only.
Hudsonly to all of our Hudson owners. Rudy and Chuck
Please add this to our message. Please contact
EMPIRE MOTORS
13451 Montana ave
El Paso Texas 79938-9616
915-856 9607
info@empiremotorsinc.com For all information about the Head0 -
You've posted this message out in the "General" forum area, where few Hudson people will see it. Had you meant to post it in the Hudson forum?0
Thanks Jon can you post it for us? I dont realy understand. can you post it for us Jon? Thanks Rudy0
