misfiring plug wire
Try changing spark plug.I have had bad plugs act that way.Why?I do not know but thay will sometimes.0
Holding the wire away from the cap means the voltage has to increase to jump across, hence if you have a bad plug (dirty, oiled up, or too wide a gap) this increased voltage causes it to fire. There used to be a proprietary gadget, back in the twenties, called a "spark intensifier" which was primarily intended to overcome misfiring problems caused by oiled up or dirty plugs. It was basically an adjustable gap in the output wire of the coil, causing this voltage build-up. Only problem is that it will inevitably lead to to coil failure, as the insulation breaks down with the excessive voltage.0
the plugs are fairly new,not oil fouled,but iwill ck. gap. if gap is ok,would just replacing plug cure prob.?0
Sometimes a plug can look good,and still be bad.(conductor inside insulater broken ect.) try trading plugs with anouther cly.and see if the mis moves with the plug or stayes where it is.0
I think I would check the INSIDE of the dist. cap for cracks and/or scratches. Check also for carbon tracking around inside. Especially around number one terminal.
Bob0 -
Swap plug t another cyclinder. See if there's any change.
Kim0
