Need rebuildable 212 engine
Long story but I am in need of a rebuildable early style 212 engine .030 over on piston bore or less with the distributor down at the rear right side . Needs to be within reasonable pick up distance from Salem Ind. and VERY reasonably priced , machine shop screwed up the last one and about broke me . Not in any big rush . Email or PM to contact me.
BUD
BUD
Have a 212 motor complete with carb and air cleaner but out of a 46 pickup that ran last year. Rear main leaks and has worn rings I am sure of. Original factory engine. Will take $400 for it, I am in central Illinois.0
russmaas wrote:
Can't put that into a Hudson from 39 down, as the distributor is at the back top of the block. Would have to rework the firewall. Walt.Have a 212 motor complete with carb and air cleaner but out of a 46 pickup that ran last year. Rear main leaks and has worn rings I am sure of. Original factory engine. Will take $400 for it, I am in central Illinois.0 -
THANKS RUSS , yeah Walt is right , and I'm sure you know , but I can't do the cut out. I've used up the space inside the car with a heater/air conditioner unit I made and want to keep it , my old bones don't like real cold/hot any more . I've got a few parts from another old junk block, head-good water pump- pan, maybe easier to say what is not good---crank-cam- lifters-block are shot , been left to mother nature before I got it . The rest I have or can transfer from the engine in the car now . Got some new .030 pistons allready cam ground, rods that need rebabbit , main shells to rebuild , spare rebuilt water pump , all that sort of stuff . Thanks , BUD0
Bud
Couldn't you use a good 175ci block? Isn't the main difference between the 175 and 212 in the crank and rods? If the block is the problem, would this work or am I overlooking the obvious? Perhaps one of the forum experts will give us the answer.
Kevin C.0 -
Kevin C. wrote:
The 175 block is the same as the 212. Just change the crank shaft, use the 212 pistons and the 212 oil pan as the 175 upper tray is set a little higher to make up for the shorter stroke. Walt.Bud
Kevin C.0 -
Kevin C. wrote:Bud
Kevin C.
Could be done but getting everything needed is cost prohibitive in my case , better to find a 212 with good crank and cam in it . I'm in no hurry , this is to replace the engine the machine shop screwed up . I have it running and driveing it but don't trust it as I know what I had to do to salvage it , {not gonna tell,you guys would run me off !} and there is nothing more that could be done with it without at least sleeving all the bores and I'm not crazy about that idea , has piston slap noticeable at about 60 mph. It could possably run a long time if I don't go drag raceing with RANDY , but it's hard to enjoy it when every time I leave the driveway I think I might have to walk home .---BUD0
