steering for a 27
essexcoupe3131
Here,s 1 for all you guys with the real early stuff, a 27 sedan Essex, when it is driving along, the front wheels wobble like you have been drinking for 8 hours straight, all the wheels are good, adjusted the steering box as there was sideways slop where the drop arm comes out,
thoughts
Mike:
thoughts
Mike:
essexcoupe3131 wrote:Here,s 1 for all you guys with the real early stuff, a 27 sedan Essex, when it is driving along, the front wheels wobble like you have been drinking for 8 hours straight, all the wheels are good, adjusted the steering box as there was sideways slop where the drop arm comes out,
thoughts
Mike:
Check your camber. I needed to loosen the front U bolts & retighten using a washer as a spacer at the rear of the beam axle. Cured the problem for me.0 -
ESSX28-1 wrote:Check your camber. I needed to loosen the front U bolts & retighten using a washer as a spacer iat the rear of the beam axle. Cured the problem for me.
I got a couple of wedges from a wheel alignment place and put under mine some time ago with good success like David got - curious though, why would this "suddenly" happen. Has the car not been on many trips prior without this problem???
Alistair0 -
We were on a run for the Auckland HET and there was a 27 sedan, I think it was the sedan with the name plate old Reliable, ironic huh,:rolleyes:
Iam not sure what the guys name was but was at the 100 anniversary in Cambridge, David if you contacted Darrin Nelson
021-748282 he will tell you who it was, Iam useless on names of all the members
Mike0 -
just got the name it was Bob Cleland 27 sedan
Mike0
