How dum can one be?
Ok, so I'm an idiot.
Now, please give an idiot some direction.
In the process of replacing the battery in my '36, I reversed the polarity. I was taking it for a ride (man, it was not running well) and had gone several miles at hiway speeds before I knew something was wrong. (No turn signals, a couple of other things didn't seem right, especially a high speed miss) I returned back to the garage before figuring it out.
So other than the obvious (switch the poles) NOW what do I do?
Thanks for bearing with me...slim
Theoretically, it should not have made any difference. However, the spark is about 15% inhibited with reversed polarity, which could explain the miss. Just switch the battery back to the original + ground and then re-polarise the generator by momentarily connecting the A terminal (that's the larger post on the generator) to the battery connection at the starter solenoid, and you should be back in action again. One of the dis-advantages of not having an ammeter!
Geoff.0 -
Golly Slim, if that's the worst boo-boo you ever did your in great shape, AND {yank-yank } THAT AIN'T NO THING , IT"S ONE CLASS ACT LITTLE COUPE !! BUD0
In the november issue of "cars and parts" in the guestions and ans. Page, there is a question from somebody else that did the same thing with a optimo battery. So it nothing new that you have done, and i dont think you are the last one that will do it. There was also a articule on changing door windows, and they used a hudson to demastrate.0
