who has replaced windows in Hash
I need to replace the side glass in my 55 Hornet. I'm looking at the door and it looks like the frame comes off with three bolts. If it does I'm thinking the glass will lift right out. Is it possible it's that easy? I'm sure Paul has replaced some glass so if you see this post Paul please chime in.
Harry
Harry
Harry - I'm not familiar with AMC Hudsons at all, but I would say you better make up your mind that the window will be replaced thru the lower part of the door. I'm sure Paullargetype will chime in here soon to give you the heads up on the process.
Jerry
53jetman0 -
Jerry that is what I was thinking until I saw the bolts holding the window frame to the top of the door. I'm really hoping I can replace the glass without pulling the wing vents.
Harry0
