Door Handles
Hi Tom,
Push in on the round plastic trim piece at the base of the handle. If you look down between the gap you have created between the trim piece, and the handle, you will see the end of a small round pin that anchors the handle to the shaft. Use a small awl, or drift to push the pin out. Make sure to spread a towel or sheet below the door before pressing out the pin, as it will save you searching around the garage floor for it if it tries to make a break for it, and rolls away! LOL. If you need to remove the window crank handle, it is held on the same way.
Hope this is a help to you.
Essexly,
Dave0
