1933 Jack and lug wrench storage
tigermoth
tigermoth Expert Adviser
edited February 19 in Parts & Pieces
Where did Hudson store the Jack and lug wrench in the ‘33 convertible and roadsters,
Not an issue now as I don’t have either. Haha.
regards, Tom
  • tigermoth
    I see the internet says either in the rumble seat or under the drivers seat for 2 door convertible coupes with rumble seat.
    anyone on here n who can confirm and perhaps post a picture of theirs so I know what to look for in jacks and lug wrench?
    thank you.
    regards, Tom
  • 5433HET
    5433HET Expert Adviser
    Well it wouldn't be under the front seat, as it is not movable,and is tight against the floor... I guess they were kept in a burlap bag in the rumble seat floor area, no provisions to fasten in place. The owners manual leaves much to be desired, no instructions about the jack, also no instructions on raising, securing or lowering the top. I assume because Briggs body co. only converted a few hundred coupes, so it wasn't deemed essential. And good luck changing or servicing the battery, for obvious reasons!
  • tigermoth
    Mine has a seat adjuster ( more show than go, as it only moves a couple of inches) the seat bottom sets in like my ‘35. It does lift out. As I am well down the list of owners, I am not sure if it is “borrowed” from another car.
    regards, Tom
  • 5433HET
    As you can see on this original '33 convertible seat, there is no room under the cushion or under the seat!
  • tigermoth
    edited February 22
    Thank you. I knew the floor was flat, I did not know if there was space between the floor and the seat springs.
    I do see the seat position adjuster. Seat moves all of about 2”.
    Is that an original jack handle in your pic?
    thank you again.
    regards, Tom
  • 5433HET
    I believe it is
  • 5433HET
    A complete '33 tool kit assembled by Kerry Haggard
  • tigermoth
    Wow, That is great. Good work Kerry.
    thank you for posting 5433HET
    tegards, Tom
