Adding Oil Filter to Splasher Engine
I’ve looked at this in the past but ended up side tracked with other things, but now I’m back on it & trying to find a good way to get some filtering to my 212ci in my 37 Hudson.
Has anyone out there use one of Frank’s Full Flow systems on their splasher engine? If so what filter is used & how was the routing done? I’m pretty sure I know the routing but confirmation is always good. If anyone had used one of his setups how has it been?
Thankfully I added a crazy strong rare earth magnetic drain plug when I rebuilt my motor that a guy in Montana sells & it’s definitely been worth its weight in Gold!
This image is at the 1st oil change at 200 miles from rebuilding the engine. Thankfully those particles were caught & not floating around doing damage:
After cleaning ready for reinstall:
Who sells these magnetic plugs and how much?
Who is the source for these magnetic drain plugs? I’d like to buy a couple.
- 97 Essex Super 6
