All Wet.
OK guys help me figure this one out. I own a 91 chevy cavalier when it gets real cold out side or it rains my floor board on the driver side turns into a lake it dont matter if it sits under the carport it still gets wet by the way i live in Washington where it rains and gets frosty cold ive serched for holes or cracks there is none which in this case it dont matter cause most of the time it sits under the carport. So does any body have any suggestions.
When you get that one figured out I hope to see the solution. I have a 92 Cavalier. I have sealed everything that even looks like it would leak. I live in Oregon.
dbldcb0 -
Do you have a sun roof?
I worked on a Barretta that had the same problem but it had a sun roof and the problem was that the drain for the roof was not connected.0 -
sorry no sun roof there is no under coating im going to try this next. This is happening throught the whole inside but mainly on the drivers side. Thanks0
im going try under coating will let ya know if this works.0
- 97 Essex Super 6
