Tips for putting on 225/75r15 rear tires on 52 hornet?
I had to take my rear tires off the other day and putting them back on was challenging to say the least. I got it done, but it was not easy. The tires are 225/75r15 and I have seen a lot of discussion about this being difficult with this size tire.
I was wondering if anyone had tips or advice on doing this that might make it easier?
Thanks in advance!
-Lance
I raise the car up by the rear frame so the rear end drops as low as possible. This gives a lot more space to work. You might get even more spring extension by disconnecting the lower end of the shocks. Side note: when I put the 275/60-15's on my car, I do this, and i have to let all the air out of the tires, then reinflate after they're bolted up to the drums.
No exactly convenient if y ou are on the road and have a puncture!
If you're on the road and get a puncture, it's already flat. I carry a normal sized spare tire.
I have jacked the car under the axle on the opposite side to get the spring to drop even more on the side you’re changing. Best on concrete with a good jack.
I did mine the same way as cheyenne did.
These are all great tips! I’ll definitely be giving them a try next time I need to remove my rear tires.
Thanks for the suggestions!
- 97 Essex Super 6
