Headlight Wiring
Another question as I install a new wire harness on my 1952 Hornet. The routing for the headlight wire to the foot switch is insane. Any tricks for being able to get it in there? It appears to go through a crack between the firewall and floorpan. Despite my best efforts, I’m coming up empty.
Doesn’t your dimmer switch mount from under the car where the wiring connections are? The wires go down the outside of the cowl to the switch.0
