Stepdown Fog Light Switch
Does anyone have a picture of a fog light switch for a 53 Hornet? I currently have my dash out of my 53 Hornet for painting and assumed that the fog light switch would be mounted in one of the two knock outs on the cluster below the temp and fuel gauges. I have another cluster with a switch mounted in that location in my parts bin, but I am beginning to think that this cluster is for a 51 and that it is a headlight switch. The switch has 3 terminals labelled B, F, and H.
The fog light kit I have is from Dale Cooper, but it has a cheap plastic rocker switch. I planned to wire the lights using the relay kit and use this switch as the low voltage trigger for the relay.0
