Grinding valve lifters
barrysweet52
This method has been mentioned a few times, but I have never seen a photo.
Have to drill and tap a hole in the piston to hold the lifter or you might wear it.
If you live in the USA new ones are available. If overseas and you have a lathe, no expensive postage is reqd.
Grinding cup and cone bearings for Delco distributer 1916 - 1926 (in Aust)
This is a good technical post, but sadly it won't get a lot of attention because it's posted under the "Instruction and Tips" on how to use the Forum. Not on how to fix your Hudson! My advice would be to post this over at the "Hudson" category of the Forum.
Jon - I moved it over to 'Hudson'. You, as an administrator, can do that as well..Jon B said:This is a good technical post, but sadly it won't get a lot of attention because it's posted under the "Instruction and Tips" on how to use the Forum. Not on how to fix your Hudson! My advice would be to post this over at the "Hudson" category of the Forum.0
