Replace bulb fender lamp Hudson eight 1934???
CURRENT IN THE VEINS 66 YEARS AFTER
1 YEAR AGO
Very easy put a blanket in front of the light in case you drop the lens now take your thumb and push the lens straight in towards the back of the light this is to make sure the lens is lose all away around the light body it dose not have to go in to far you just want to make sure it is lose now you just push the lens straight back while also pushing the lens up toward the inside the light body at this time the botton of the lens should be sticking out lightly pull on the botton of the lens pulling it out and downward the lens should be out know so change the bulb and replace the lens in reverse order I hope this helps.0
Thank you. In the meantime I was able to unmount myself. Good block. Rare and fragile glass ;Bulb Mazda
For reassembly;j waits for your mail
Replace bulbe interior???
There is a snap ring at the outside edge of the glass.0
Thanks for the confirmation.I had noticed;but apparently well-gripped ring
I see that you have a felt type washer can you tell me were it goes I do not have any in mine I put my set together with parts I collected over time I also did not know there was a rubber pad on the bottom thanks Tom.0
felt between the reflector and ice.Original 1934
do you mean between the reflector and the lens and could you tell me the size of the felt I will have to buy some and make my own thanks Tom.0
JACK356 could you please post the measurements of the felt washer I have to make some for my lights thanks Tom.0
I'm looking at this. I'm working this weekend
Thickness 3MM FELT
Thank you so much one other thing that I need is to know witch way the cup washer on the bottom of the base goes on I know it goes under the fender I need know witch way it is faceing when you put the nut on could you please post a picture of your base with the washer and nut on it so I put mine on the car the right way thanks Tom.0
Ok tomorrow0
Thank you very much for every thing you are doing for me Tom.0
Original 1934
Once again thank you can you tell me is your gasket made out of rubber that is the last part I will have to find somewere to complete my lights Tom.0
Incredible origin
Épaisseur 3MM FEUTRE OK
chambre à air
Replacement.FASTER AND EASIER;
unseating the two screws from the support underneath.MOUNT THE JOINT pushing the reflector.Put the ice down.Push.and put it up. 3 min.
Jack:
Rubber mounting pads are available for 1934 at Wildrick's, for $32 apiece.
https://lh3.googleusercontent.com/pKIqVCyiheQsulgjxwCdrwFylDaBP9cGb43z-VrBvxqUPQThZMDT0Ni_dFLiWHFzeqEWilYL0ytXyahDBH1pB5o5Nw597eGxO32IItHKrLx9LHoQwIG-=w1280
Here is the webpage: https://www.wrphet.com/hudson-mounting-pads
Jon B thank you so much for the information I called them and he is going to fix me up with them they were the last thing I needed to complete my lights.0
Jon B said:Jack:
the joints are like new
Tapez votre commentaire0 -
Have you;references the hudson 1934 rear bulbs;left with the plate and right. Thank you
Jack356 could you tell me were the wire from your fender light goes after you mount the light is in attached to the fender somewere or dose it just go through inner fender panel and tie into the wireing somewere I am adding these lights to my car so I do not know were the wire goes thanks.0
For the backlight. The wiring is attached with small original fasteners along the chassis
Jack356 I am sorry I was talking about your front small fender light that you just replaced the bulb in I am adding these lights to my car and I wanted to know how the wire attached to the bottom of the fender and were it went into the engine bay.0
The wire passes over the wing support. Return with the headlight cables into the engine bay through the same hole
Tapez votre c
ommentaire 0
- 97 Essex Super 6
