Master cylinder
They are a different part number, but are the same size, so it should fit.0
So - you can use a Senior model master cylinder on a Jet, but not the other way round it would appear. I'm sure the bolt pattern is the same.0
You are right, (as always) Ken. If you can find an original part, use it!0
