Help with wire routing.
keithfullmeryahoocom
Is there anything like a wiring routing diagram that would be helpful showing final locations of wiring? I have the schematic diagram, but it is not much help in this regard. Thank you in advance. keith
I have done the wiring with kits and from scratch. If you are doing a car pre-WWII they are quite simple. If it is later, i.e. a stepdown, and this is your first car I would go with a wiring harness from one of the companies we often hear about. I will add here, that when I wire a car, I never run the wires under the car as was most often done by the factory. And, more often than not, I will place the wires in hidden places (like the frame) to make the job look cleaner. Other than that, It is quite simple......
Thank you for your tips and kind support. I have the complete YnZ harness and have done several old Fords from scratch. I will proceed the best I can. Keith
