part number for 48 Points and Condenser?
forgive the basic question but i have searched as far as I can tell and can't find a NAPA part # for a replacement set of points and condenser for the 48 commodore (either oem or an alternate type). i am going to 12v so I think I actually need to mate the condenser to the new 12v coil. I am just unsure as to whether I need to get a set of points to match the oem style or if I need to find a set to go with the 12v setup?
Obv I'm new to all this but am trying to learn as best I can. I appreciate all the continued help.
- jason
Points are a mechanical switch and are voltage independent. Use correct pints for the distributor used. Use the info found on my website http://hudsonrestoration1948-54.com/index.html#RESTORATIONAIDS Select parts swap manual And find ignition parts0
thanks OldFarmer0
These are the ones on my list, also on the Hudson website. Points
Standard
AL4652XP
Big 6
