1953 Jet-2 door
ksteele
in Street Rods
What kind of engine can I use in a Jet that won't die in a city and will let me have a more drivable Hudson?
I have owned my '53 Super Jet since Oct. 1966, and it has never let me down on the road. The original engine is more than capable of powering the car IF it is tuned according to info in the mechanical procedure manual. You can down-load a copy of the Jet Mechanical Procedure Manual from the club library, or just down-load the pages you need for what ever you happen to be working on at the time.
I have had my Jet for 45 years, and never had it fail apart form one time when it suffered form vapour lock on an extremely hot day, on an extremely steep hill. If you have the proper heat insulation for the fuel pump, and deflector for the carburetor you should have no problem. It seems extreme to replace the engine for what is most likely a small issueGeoff0
Do you both drive yours daily?0
Used to drive it for my work, in conjunction with my 1928 Essex, but nearly 80 now, so don't use it as much. Still available as a daily driver though. Has always been a good reliable and economical vehicle. Has single carb, 3 speed o/d. I would have no hesitation in driving on long trip. Very comfortable, and much more practical to use than my '53 Hornet, which has "Wow" factor, but a dog of a thing aorund town.Geoff0
The Hudson Jets have a very high horsepower to weight ratio. With Twin-H they were the quickest car in the US auto industry. Why go to the trouble and expense to change the drive train?
What is the serial number on that Jet? Hudson only made Jet 2 doors in 1954 and called the body style "club sedan". All '53 Jets were 4 door sedans. Unless you have a discovery to show us.
I don't have the serial number just a photo and I attached the page from 2017 car collector price guide. They didn't make very many but we have one and I'd like to drive it in the city as my car.0
The jet 202 engine is very reliable. Just like any other engine and even new ones, just give proper maintenance. EASY TO WORK ON!0
Have you experienced any specific engine trouble, and if so, what?
Or, are you simply contemplating driving it, and worry that it's an old engine and thus might give you problems?
If you wanted to drive it regularly, you would be well advised to go over it from top to bottom, renewing parts and testing things to make sure it's in top shape. Perhaps you can't cruise at 80 mph as you can with a modern car, but these cars were designed and built in the 1950's, for everyday usage. People drove them regularly, hard, and across the country. Naturally, all cars in those days required a bit more maintenance than today's cars, so you might have to change points, oil, and various filters more often than if this were a more modern car. But overall, I think it would serve you well, so long as you take the time to renew the engine so it's at least up to 1953 standards.
May I add that on the other end of this issue is getting it stopped. Make sure the braking system is in tip-top shape. Some say the brakes were inadequate from the factory but I believe that if they're in proper condition and the car is driven sanely, they do just fine. However, in the absence of the mechanical back-up system used in the senior Hudsons, I'd recommend a conversion to a split-tandem system in place of the single circuit original version. My motto: "Make 'em stop before you make 'em go".
Frank
StillOut THere saidWhat is the serial number on that Jet? Hudson only made Jet 2 doors in 1954 and called the body style "club sedan". All '53 Jets were 4 door sedans. Unless you have a discovery to show us. Quote:0
StillOut There - I can verify that there are truly '53 Super Jet Club Sedans. We have at least 12 of them in the hudson Jet Registry. The earliest serial number I have is 2C237707 which would have been built in March of 1953.
Jetman-I don't think I ever registared my car with you. I think I sent the info to Sara some time ago. It is a Super Jet Club coupe. #2C264598.0
Thankx for the info. Would like to have your full name and address,and approx. date you purchased the car. My e-mail: HudsonJetman@yahoo.com
Thanks, I'm still learning.53jetman said:StillOut There - I can verify that there are truly '53 Super Jet Club Sedans. We have at least 12 of them in the hudson Jet Registry. The earliest serial number I have is 2C237707 which would have been built in March of 1953.
- 97 Essex Super 6
