quick question about new single master cylinder
i just got the new master cyl from napa per the forum part interchange page. It's a single resevoir but only has 1 outlet at back instead of the 2 outlets on top like the stock one. I am curious if i should run a proportioning valve to the rear brakes or simply run everything off the 1 outlet in "series" - via tee's etc? i also have to account for a brake switch.
any thoughts?
thanks
- jason
Can you post a picture of the two?
thanks Ken - how may i place an order?0
